Would it be safe to assume the b14 has it in the same location?NoVTECSER said:The knock sensor is on the back of the block, under the intake manifold. If you know where the oil pressure sending unit is, it's right above that. Good luck getting to it though, its up there.
I don't think it's your knock sensor chucky200sx.I ordered one from the dealer but i returned it because my old sensor was fine.chucky200sx said:Would it be safe to assume the b14 has it in the same location?![]()
Thanks![]()
