okay. i hooked up consult at work and checked the stored codes. knock sensor at time 0. and o2 sensor at time 10. i cleared the o2 code. the knock sensor code wont clear. i check it again a week later. still throwing the code at 0. whenever time = 0, something is currently wrong with it. does anyone know how knock sensor works, i know it only has one wire going to it. is that wire a ground? a power? the sensor is new so im not going to replace it until i rule out a wiring problem. but i dont know what to check for.
also, the o2 sensor code reappeared again. last thing i did was lengthen the o2 sensor wires. i know i matched up those wires right. its the OEM o2 sensor never ben replaced. you guys think its time for a new one? thanks
-Aaron
-Aaron
