1 - 16 of 16 Posts
· NX Lightweight Not SE-R
Hiya,
There was some mixed posts on this problem already. Can someone give me a definate answer?
When exiting my driveway, I hear something like a broom, or a stick hitting my car. The sound is from the front right.It is only aparent while amongst slow left turns, and a hard turn of the steering wheel.
That is it thanks.
jere
sounds like the cv joint to me...but i'm no expert
· SR powered S13 coupe
Actually it sounds like one of the front sway bar end-links bushings has failed (or washers for the bushing). This will cause a knock when going over speed bumps, out of driveways, and when the body weight shifts causing the knock you describe.
Check your end-links and see if either side is damaged
-Monty
how long can a bad CV run? sorry to hijack the thread...
· Learn to swim
I guess that some could last a while, but mine only last me long enough to get to the store and buy a new axle. It's an easy job to do, and the cost is nothing compared to the damage a broken axle could cause at a decent speed...Josh
Discussion Starter · #14 ·
It was the sway's bolt. I missed it when I jacked it up because it tighted up. On the ground I could spin it by hand.
Thanks Monty, you had it.
Thanks,everyone for the help.
1 - 16 of 16 Posts
