Guest
·Guest
Hey out there. I'm running a stock '92 SE-R. The heat doesn't work well even with a higher temp thermostat. The air isn't coming out hot. I've tweeked the temp lever into max position down below- it seems to control an air flow door, not a water flow valve (just left of passenger foot compartment, above plastic shield). When you move the temp lever, is there something somewhere that moderates water flow that isn't opening all the way?
Also, I need to have my fifth gear pop out fixed. What kind of price range have people paid to have this fixed and do you need the new fifth input gear as well as the shifter fork?
