1 - 15 of 15 Posts
91 SER Richmond, VA
Leaking Brake fluid I think?? (Found the leak!! Now what??)
Its been a problem for a while now, but its gotten really really bad lately. The brake light keeps comming on and my friend advised me to put in brake fluid. I do, and it comes back on w/in a week. Is this a brake fluid leak? He also said it might be b/c I have low calipers, but before I go and take off the wheels (its still cold here) I wanted to see if I could get some other options. If it is a brake fluid leak, where should I start to check?! Thanks guys!
-Mike
Are your brakes hard or do they feel like a sponge? If you have a leak, often air is introduced into the system. Like greg said, check for puddles. You didnt say if the brake fluid was low when you filled it up. Was it? Did the level go down? And by low calipers I assume you mean that the pads are worn down. Check that as well.
-Mike
91 SER Richmond, VA
Ya, I meant pads, sorry. I was half asleep posting that. And yes, the brake feels spongy when I press it. Ill try to check for puddles, but where I park is kinda on a hill and dirt so...Im not sure how well that will work. Its warm today, so I think ill pop the wheels off and see what I can find. Also, the brake fluid was below the min line when I filled it up this last time and when I filled it up before that, it was passed the max mark.
-Mike
91 SER Richmond, VA
Alright, Ill check that out too! Off I go!
-Mike
91 SER Richmond, VA
Discussion Starter · #7 · (Edited)
I do believe i found the leak, seeing as the fluid was about to drip when I took the photo. The last one is a really weird angle, but its the best I could do. What do I have to do to replace/fix this??
Edit: You cant really see it that well, but its comming from the little round thing beside the screw in the second picture.
-Mike
91 SER Richmond, VA
I checked the master cylinder, didnt seem to find anything out of the ordinary, but I also didn't take it all apart. I think this is the problem, but its such a small drip Im not sure.
-Mike
A small drip really flows when you hit the brakes.
I can't figure out what that picture is though is that the front or rear of the car?
sometimes brake fluid will leak from one area and drip down the brake lines to a totally different area. chck to see if it is actually coming from there, and if it is a fitting, try to tighten it up a bit.
--Eric
I think its the rear brakes, but its hard to tell. I think I see the ebrake cable. Is it leaking from the brake hose? If its leaking at the banjo bolt or whatever it is, you might just need a new washer or to tighten it down. I had a small leak in the rear when I did my ss lines from not tightening it enough. If you need to replace the line, I have the stock se-r brake lines you can have for very very cheap. I will be in richmond on tuesday too.
-Mike
91 SER Richmond, VA
Discussion Starter · #13 ·
Its the rear passenger brake. Sorry, my digi cam sucks. Ill check to see where its leaking tomorrow (suns doing down now) and see if I can tighten anything.
-Mike
91 SER Richmond, VA
Discussion Starter · #15 ·
Nah, I didnt get to check it out today (fuel pump went in instead). Tomorrow I work, so itll be about another week or so. Ill keep ya updated as to whats happenin.
-Mike
1 - 15 of 15 Posts
