Re: Re: Re: Leaky header
My motor mounts are good. The welding job on my first header and downpipe was obviously lacking, especially since the first header itself was missing a 1/4 inch piece of weld around one of the pipes. I didn't think there was anything wrong with the downpipe welding, so I only sent the header itself back. I installed the new header they sent me, and the first downpipe. Upon examination of the downpipe about a month after the install there was a leak at one of the welds. I had thought the buzzing sound I had ever since the install was completed may have been a result of that leak. However, it wasn't. The leak didn't create any noise, because the new downpipe Hotshot sent me makes the same noise, and doesn't appear to be leaking from the flex-pipe. Headers are a pain in the ass, but are worth the performance gain. I just talked to someone last night who is going through the exact same crap I went through with a header he bought for his car.
If all of that was confusing, here is what happened broken down better:
1st Header
Never installed
1/4 inch piece of weld missing around far-left pipe.
2nd Header
Installed
No issues
1st Downpipe
Installed
Noisy from day one
Leak detected at flexpipe weld one month after install.
2nd Downpipe
Installed
Same noise as 1st downpipe
No issues, besides a leak from secondaries gasket (easily fixed by re-torquing the bolts).
Pretty White said:
Both flex pipes? Are you sure your motor mounts are good?
