1 - 9 of 9 Posts
I'm curious...everyone has the fuel guage light that glows yellow when you're getting near empty, right? Mine goes off right at the "F" line, but I've noticed that when I fill the car up, I can only fit 11 or so Gallons into the tank(It holds 13 gal.)-What amount of Gas should be in the tank for that light to go on? Is it like 2 gal. or something?
G-unit
Be glad yours comes on before you are empty!!! Mine comes on about the time I need to be turning in the gas station. Mine has come on twice BOTH times it toke 12.5 gallons, SCARY!!!
From my experience, the gas gauges on Nissans are not that accurate. My old Sentra could run on E for like 100 miles, and when I would fill up the tank, I could still only put in about 10 gallons.
When my gas light comes on, I can usually put about 11-12 gallons in the car, so I'm guessing that the light comes on when you have about 2 gallons left.
AWD owns me
Man, you guys are lucky you even havre a damn gas light.93 SE-R
AWD owns me
Hmmmm, my bad. I finally saw it yesterday. Kinda poor design. Little orange dot.
Hey guys, I have the same problem with my '91, except I can only get about 8.5 gallons when I fill it. I found the problem on SE-R.net though. Chances are the remote sending unit is bad. Its a device in the gas tank that measures and sends the signal to the fuel gauge as to what the level is.
The link to the article is here:
www.se-r.net/car_info/problems/fuel_gauge.html
Hope this helps out. I plan on replacing mine in a few weeks. I will post my results.
Jason
Thanks for the info, Jason(the link didn't work,BTW)-I think I've finally figured out that the light goes on when there's about 2-2.5 gallons left. I surmised this from basically driving the gas all the way down till the light went on, and drove around gritting my teeth hoping I wouldn't run outta gas. When I finally couldn't stand the suspense anymore, I pulled into a gas station and filled up...I ended up putting in 11.5 gallons, and I had been driving around with the light on for 40 or so miles. So hopefully, that will solve that problem-I just have to remember that the guage is "pessimistic"
1 - 9 of 9 Posts
