1)That unit is the same piece. It is called the "J" pipe. The O2 sensor is housed in the unit so you will need an O2 bung to fit your sensor. It's only $3 or so.
2)It depends on if the center section is water cooled or not. If so, you can tap into the coolant line behind the block for feed and return.
3)Dude, don't feel stupid. Just consider yourself a turbo novice who needs a little support (and a kick) to get started. NOS runs out, boost is ALWAYS there!
[/B][/QUOTE]
321.2 HP @ 6500 RPM
285.1 ft/lb @ 5300 RPM
3 bar Program w/50lb injectors...TO4E/T3 Stage II
12.81 @ 116.8 mph
Built motor in future plans!
[/B][/QUOTE]
321.2 HP @ 6500 RPM
12.81 @ 116.8 mph
