Give it the usual used car once over.
But some of the specifics that I can think of off the top of my head would be:
Make sure third gear isn't difficult to get into. If it is, you'll be in for a trans rebuild.
Rust. Especially around the A-pillars.
The overall condition of the car. And make sure there aren't any aftermarket body panels. A sure sign of a accident.
Thomas Fox
'93 NX2000
www.geocities.com/subcltr_nx2000/Homepage.html
Bring a magnet with you and check for damage repair by sticking the magnet to the car in different places It wo't stick to the bumpers). If it doesn't stick to the metal, then bomdo has been used for repair.
Try to start the from a stop in second and third gear. If it pulls out okay, the clutch is probably pretty good.
Look at the T-tops for busted seals.
Try the fan switch in all four positions and make sure they all work.
Turn on the fog lights and make sure they both work (They will only come on with the headlights).
Check for water in the spare tire well.
I'm sure there's stuff I'm forgetting, but this should be a good start.
Ben,
'93 NX
