1 - 2 of 2 Posts
Fmax Stg II B13
Hey... I lost my instructions and can't figure out which wire is what for the Greddy EGT guage... there is a harness with 4 wires, (red, white, black and orange) I know I have power and ground (red and black?) and one of the others should be illumination? Do you by chance know which wire is for what and where I should tap them to?
Thanks.
Brian
AIM: pdxs2000
91 se-r (fmax stg2 @ 1.1 bar)
00 s2000
Red= power
Black= ground
White= light
Orange= ignition on
I hope this helps. If you still need the manual, I can fax it to you this afternoon.
Louis Anaya 1992 Sentra SE-R Bluebird SR20DET w/ GTiR Pistons,T3/T04E,Deltagate Wastegate (9 PSI) FMAX Manifold, RevHard FMIC, JWT S3 Cams, JWT Ported & Polished Head, 1996 200SX SE-R Welded & Cyro Treated Tranny, ACT Xtreme P/PL & 6 Puck Disc, Cobra MAF, JWT ECU w/ 4 Bar Fuel Program, MSD 50lb/hr Injectors, JWT Fuel Rail, 300ZXTT Fuel Pump, AeroMotive Adjustable Fuel Pressure Regulator, Greddy Profec B, Greddy Boost & EGT Guages, UR 4 Pulley Kit, Powerslot Rotors, Axxis MM Brake Pads, ES Motor Mounts, Topspeed Short Shifter, Momo Cobra Shift Knob, KYB AGX Struts, GC Coilovers (350F/600R)& 17x7 White Tenzo Shu-4's w/ Kuhmo 205/40/ZR17 Tires
1 - 2 of 2 Posts
