Low Vacuum???
968 Views 1 Reply 2 Participants Last post by  charlie2020
OK, I thought I had a vacuum leak, probably still do but I can't seem to find it.
I'm reading 10-12in at idle (900rpm). I've disconnected everything, plugged everything, pressurized everything, squirted propane all over the engine bay, and I can't find any friggin' leaks.
I haven't messed with the idle control solenoids on the right side of the intake. Could they cause a vac leak?
Is there any reason that I shouldn't be running 18-20in of vac? Too much valve overlap? Low compression? I can't figure it out...
Maybe the intake manifold has a leak in the gasket somewhere? I would think that I would have found it with the propane...
Thanks in advance for any help...
Gabe
1 - 2 of 2 Posts
Maybe one day u can drive it over to my house if its drivable. What car is it and what mods you got done to it.
1 - 2 of 2 Posts
