sorry brian, I have to disagree. If it improved flow, it would improve the horsepower/torque.
I did turn mine, though, when I installed the PRCAI. Just because it was easier to install that way.
oh, ok, I thought that there was a small blockage where the actual sensor is, but when turned around there was nothing. oh well, everybody is wrong every once and a while (this was just something I have heard, but not a solid fact anyways)
Thereis a hole for the air to go through and a small blockage, which is the actual sensor. Rotating the maf does not change anything, because your just spinning a circle. Now if you flipped it over, that would be changing things, but the sensor wouldn't be facing the airflow, which I would guess could cause problems.
Look, you can fiddle with the MAF all you want and you won't gain anything, except maybe a loose harness connection. You want free and cheap HP, advance your ignition timming.
Timing's already at 17°. I've seen several rotated MAF's with CAI's, and am just curious.
Something to ponder, though: If you orient the MAF in such a way as to place the portal on the outside of the bend, the air should be moving slightly faster than the air on the inside of the bend(sensor). The difference is slight, but there. Fluid dynamics at work, but to what gain? Oh well, the things I ponder.....
Well the only way to find out would be from back to back dyno testing. I might work. If it does then I will be more than willing to admit that I was wrong.
