1 - 2 of 2 Posts
I have the stock s13 SR20DET intake manifold. I have a standalone ECU with a MAP sensor integrated into the unit. The stock manifold only has 3 vacuum sources. The brake booster (On rear plenum), FPR and BOV (On throttle body).
I am running a brake booster delete kit running on pure hydraulics so that allows me to free up a vacuum source from the plenum directly. I was curious if this is a good source to use for my MAP sensor?
In theory it should work but I have not ever heard or seen anyone do this, thoughts?
there's mine, top of plenum next to the iat sensor. should work fine
1978
1 - 2 of 2 Posts
