1 - 20 of 20 Posts
Hi,
How can I squeeze the most possible horsepower out of my car and keep in as a daily driver?
How far can I advance the timing on 91 octane? (15 degrees?)
Would a port and polish be beneficial for a sr20de?
would boring the engine significantly increase my horsepower?
So far, I have magnaflow 2.25 exhaust system
k&n filter where my airbox was...
I constantly run against turboed eclipses and the same chrysler conquest TSI and am sick of being beat.
sleeper
blueprinted motor, low compression pistons, forged rods, bored out to 90mm, sleeved block, 5 angle valve job, no exhaust, huge turbo, cams, short runner intake manifold, and some NOS to spool up the turbo so you still have drivablility.
To answer your questions:
1. Theoretically up to 17 degrees
2. Yes
3. Depends
NismoNX said:
Hi,
Best cheap power?
Wait until the Gen 6 Hotshot header comes out, make a 3" exhaust with Magnaflow mufflers, JWT S5 cams and timing gears, Unorthadox UD pulleys, JWT ECU, Hotshot CAI, Nismo FPR. Tune cams, timing and fuel pressure on a dyno. With an O2 injection intake manfold it might push 180's.
Should make high 160's low 170's, should eat a stock GSR or Type R or GST.
Or buy a Turbonetics Stage 2 turbo system and kill everybody.
Mike
aka Mr Ryte on G20.net
VE or DET.
Nuf said.
GT2835R
DAMN right^^. If you wanna stay all motor get a VE. You can spend countless dollars building an all motor DE thats somewhat streetable, and it will still be beaten be a VE that entirely streetable. My car has S4 cams, which were the biggest street cams from JWT before the new s5s coming out, and I have trouble in stop and go traffic, and it lags on the botton end and a little mid. A JWT ecu and cam gears will help, but still wont be as good as a stock VE.
LEARN AND TUNE IT YOURSELF.
154HP here.
Pacesetter header
HOME MADE INTAKE
HOME MADE EXHAUST
2 pulley set.
NOONE can match me with those mods.
NismoNX said:
Hi,
15-17 is spec stock for 89 octane, you can do up to 19 degrees from my expierience on 91 before it starts detonating.
Banned
Im Gonna Be Close Fig Lol.i Have Homemade Exhaust But The Rest Are Bought.
That said, let's leave it at that and just move forward.....
1 - 20 of 20 Posts
