Pew Pew Pew
Well it looks as if the time has finally come. I will be installing my new clutch and flywheel this weekend. I plan on printing out the tips on se-r.net, and I have the Hayne's manual. Is there any tips anyone can shed so as to help the install along? I have faith that I can do it, I just want to make sure to cover all bases. Anyhow I have a 96 200sx se-r. Thanks for the help
96 se-r with a few goodies
your doing it along? You cant even find a friend to help you out? The only tip I got is when you are buting it back in dont use the jack to lift it up and in. Go with the bench press. just get under the car feet to the rear and set the tranny on you chest and press it up and in.
MarC
Get two jack's as well and don't forget a flywheel lock to remove and torqe the flywheel
<---because this is what your going to do somewhere in the middle of the install.
fast but not fast enough!
[This message has been edited by 91SE-R (edited 06-11-2001).]
