bartown
pick this up from a fellow member.
-SR16VE block
-90mm bore using darton sleeves(bored and honed using torque plate)
-Custom CP pistons 10:1
-Carrillo H beam rods with CARR bolts
-ACL Rod Bearings
-ACL Thrust Bearings
-ACL Main Bearings
-19mm rod bearing machining
-Calico coated Pistons, top and sides
-Calico coated all bearings
-ARP Mainstuds
-VE oil pump
-1/2" Maxworx headstud kits
-PE/Mazworx 90mm headgasket
-resize line bore
-check,balance, polish OEM 8cw crank
-resurfaced block with front cover
-balanced assembly
AKA-- JJKAMIKAZE
has this motor been ran? i was just looking at buying a built shortblock from them so im interested. why are you selling?
bartown
Shortblock was never ran as is from mazworx. Why selling....... i was planing to build from start buy recently i bought a car that is already built.
