I was wondering for those who have either mechanical oil pressure or fuel pressure; has the line ever broke and fuel or oil got in your car? Or should I not worry about getting fuel or oil into my frlom the gauge? Thanx in advance.
-Jerrod
rollin 4 deep with JoeD
I've used both nylon and copper lines for my mechanical oil pressure gauge, and have never had a leak.
Just be careful how you route the lines. Of course the best answer is some steel braided line, which I plan on using here in the near future.
Good luck.
Bitter Old Man
NEVER route fuel through the passenger area. There is no good reason to expose passengers to a possible gasoline spill. Use a sender to bring an electrical signal inside.
As to oil, I'd shy away from a plastic tube, use either copper or stainless tubing or maybe braided stainless if you can afford it or want the bling.
anyone else?
