1 - 10 of 10 Posts
SR20VE or a T28? I dunno!
What's the minimum front and rear rotor thickness needed for turning rotors. I have heard the fronts are 16mm, but I don't know about the rear... Thanks!
just workin'
just get new one's unless you are gonna turn them yourself, do some searching on the net, you can find a decent price, i don't think its worth paying someone for when you end up with a weaker rotor
Thanks for the comments, but I want answers. This will help other owners who are wondering the same thing... I'd look it up in my manual, but I'm at werk...
se-riusb14 said:
It is stamped on the rotor itself. Its probably hidden by a lot of brake dust though.
So it's usually dependent on the rotor manufacturer, not OEM spec?
reverm said:
I gave you an answer. It's 6 mm.
I know you did :D
Is that front or rear, cause I'm thinking that's for the rear...
Captain Slow
98SERwTricks said:
I know you did :D
It's for the rear. The fronts are 16 mm as you said.
As for the specs, it's really OEM specs rather than rotor specs. With properly designed/cast rotors, you should have no problem with its rigidity down to the minimum thickness.
Discussion Starter · #10 ·
:cool: Thanks!
1 - 10 of 10 Posts
