1 - 18 of 18 Posts
sleeper
91 se-r jwt 3 bar 555cc nismo injectors cobra maf. the motor is sr20de 9.5.1 gtir kit 3 in downpipe s3 cams. 7psi. No boost leaks, also have greddy type s bov recirculated and front mount intercooler. I have searched a few other post and found that a JDM o2 sensor can cause this miss during mid throttle betweeen 3k to 4k? THe car fills strong just hesitates around 3k around 4k after 4k it just pulls.
I can feel it at idle when i rev right above 3k it misses? I have checked the basics cap wires new spark plugs stock gap, fuel filter. Any suggestions would be great.
Need to check Maf ,tps
could it be a bad injector?
Mark
91 se-r
7psi
sleeper
gap is stock .035 should i bring it down to .032
Mark
91 se-r
7psi
sleeper
Could the jdm O2 sensor cause this since i am running a JWT ecu?
oh so LAZY
I dont think so, A friend and I have both been running without any o2 sensor for over a year with no problems whatsoever.
You should probably swap it for a stock one though.
sleeper
interesting... nothing else you can think of but spark plugs?
sleeper
no wide band.... How to check for injector problems... Could there be a bad seat in one of injectors? in a few days I will have the blitz optional harness for the readings of my tps,maf,volts, oil pressure, and injector duty cylce.
Mark
oh so LAZY
Mark
I doubt its an injector, but it could be a leak around one of them I suppose. It is always best to lube up the o-rings with vasaline before you put them in.
sleeper
Discussion Starter · #11 ·
anyway to check if they are leaking?
I have a '94 DE + T3, S3 cams, 50lb.(525cc) inj., JWT ECU, *edit* J30/Z32 MAF, 9psi.
Plugs were gapped at 0.035", and it would completely stall at about 5.5K RPM.
Dropped the gap to 0.030" and it helped a bit, but still stalled at around 6K.
Now at 0.027" and all is good!
oh so LAZY
yes, let it idle and spray carb cleaner around them while it is idling, if the car sputters they are leaking.
I severly doubt that it is a vac/boost leak. Have you checked your plugs yet or not?? does it do it only under boost, or all the time?
sleeper
Discussion Starter · #18 ·
timing was off now back @15 and changed the gap. I think its all good. Thanks for all the suggestions.
Mark
91 se-r
7psi
1 - 18 of 18 Posts
