This is great. It has to be either a fuel or spark issue would be my guess. The car was running pretty good on my one test run yesterday. Of course I put insurance back on it and go for a drive today and now I get a loss of power/hesitation in throttle response. It's so bad it's unsafe. It seems to mostly be a problem at partial throttle, but the car still doesn't feel as responsive at WOT either. I just don't noticed the hesitation at WOT nearly as much.
Here's what I've done so far...
1) Checked all the spark plug connections (I used the NGK plugs and OEM wires from my old engine which worked good 6 mos ago)
2) Changed out the cap and rotor in favor for my old engine
3) Changed the fuel filter
No luck still. I'm thinking of changing out the ignition coil from my old engine as well. If that doesn't work...maybe swap out the fuel rail + injectors.
Any other suggestions would be greatly appreciated. TIA
