Hey Mismo42... I recently did my motor mounts on my '93.. I have the ES torque set (dog bone and rear-firewall mount inserts) and a Nissan OEM Passenger side mount from Courtesy Nissan. The dogbone was a pain in the ass to get the bushings pressed in, but with WD-40,a vice and two boards (to distribute the clamping force) I got it done (off the car, bushings pressed in , and back on) in about 45 minutes. The passenger side is a pain too, just be sure to jack the engine high enough so you take the pressure off the bolts; I didn't have it high enough and about stripped the top engine bolt... the rear mount is fun if you like to lay under your car... you just pull the two bolts front and rear holding the cradle and the bolts attaching the dogbone and rear mount to the engine and the cradle will fall down. Then, you just swap out the mounts and put it all back together (course I took the time to paint mine with a nice coat of Krylon black and re-weld the joints that were cracked)... I'm getting ready to do the rear mount this week- I haven't had time to get to it to install the ES inserts yet, but I did pull the cradle a while back to check the mount and see if it was cracked (it is a little... Mounts make a HUGE difference in the way the car handles and launches, and is probably the best thing I have done so far as a "mod" (and my car only has 53,xxx miles on it!!!) Anyway, that is my experience... also- check the se-r.net web site; it helped me a lot...........
NXDude '93 NX 2k w/ghetto airbox,new motor mounts, Redline MT90,Courtesy STB, and lots of dreams about having a fast car...
