I do! I do! I do!
Actually, I know how to hook one up on a '93. Which I imagine isn't too far off a '95+ car...
Basically, you're cutting the connector that goes into your coil, Mike. That gray connector has two wires going into it: (On '93s) a Green w/yellow stripe wire (+ positive), and a Black w/red stripe wire (- negative). These two wires are the ones you'll be cutting.
Important Part Here: You need to leave enough wire coming out of that gray connector, as you'll be hooking up two wires (from the MSD D6) to it. There's not much slack in those wires, so working space will be tight. YMMV. Look at my setup, so you know how close you'll cut the wires going into the connector that attaches to the coil on the bottom:
Use the instructions in the MSD box for General Import Wiring, and you'll have a great idea of what goes where.
As for colors/what matches up to what (again, this is for a '93, but should do fine):
MSD Black wire ---> Black/Red wire going into the connector.
MSD Orange wire ---> Green/Yellow wire going into the connector
MSD Red (not the power wire for the box, the thinner-gauge one) ---> Green/Yellow wire on the wire-only side of the cut you made.
MSD White wire ---> Black/Red wire on the wire-only side of the cut.
Again,your car may be different, but probably not by much. If you can't figure out which wire is + or -, just guess and hook it up. If the car doesn't fire, then switch connectors on one side of where you cut. Try again. If not, switch on the other side. Eventually, you'll get the right combination, as the car will only fire when all is right.
You'll like the MSD D6 a lot. I do.
I hope this is of help. It was bitch figuring this out all alone when I did my install, and know that some help is better than no help.
If you need any more info...just email me:
[email protected]
Greg Perry, '93 SE-R w/ 149,000 miles, JWT pop, header, ProActive
clutch, ST bar, NOS direct-port 75hp, Autopower 4-point roll bar/harnesses.
[email protected] 1/4 mile,
[email protected] 1/8 mile, 1.98 60-ft.
My SE-R page, with videos
[This message has been edited by SERprise In WV (edited 08-17-2001).]
