I am installing msd digital 6 + on my 93 b13 gti-r motor I have everything installed and wired up(thick red and black to batt ,black / red from oe coil pos to the red wire on the msd box orange and black from msd to blaster coil ) the led comes on when I turn my key to the on pos but no spark I checked the green/ yellow wire (oe coil neg ) and it has no contunity to ground so I did the test procedure and remove the coil wire place it 1/2 inch from ground tap the white wire to ground and it sparked from the coil wire to ground went a step further and pulled a plug wire plugged in a old spark plug hooked the coil wire back up tapped the white wire to ground and it sparked . so where are you guys putting the white wire ?
