1 - 2 of 2 Posts
LoSe-R
My clutch has about an inch of freeplay. So is there an adjustment screw for the pedal? I know how to adjust the clutch cable but not the pedal... i imagine that im gonna be on my head with my feet on the headrests but it wont be the first time.
well, the freeplay is dependant on the engage point. if you set your cable so that your clutch engages high, then you'll get less of the freeplay. i would rather do that than adjust the freeplay cuz its quite tedious to work down there. if you really want to do it tho than just peek down there at the clutch pedal. there should be a bolt+nut setup... i really can't describe it in detail because i don't remember. but if you see it it'll be common sense on how to adjust it.
1 - 2 of 2 Posts
