I know I always wanted to hear some info on this system, so I'll try and tell about it alittle. Mind you I don't have my bottle warmer yet, and I do live in Oregon (40-55 degrees right now), so I'm not running full psi yet.
There is a switch to turn off and on the solenoid. In on position when you hit WOT it kicks over to the nitrous program. And soon as you lift your foot alittle it switches back to the performance program again.
When you're in like third gear, then flick the switch and then floor it, it seems there is a slight delay, then the car starts taking off, then accelerates harder, and Harder, and HARDER! Feels almost like a turbo in this aspect. It is very controllable, and the power comes on smooth and linear.
Now if you're flooring it already then flick the switch, you don't get that "lazy" initial feeling, it just simply takes off! Yes I have tried it a couple of times in first gear, not to hard, just watch for wheel spin. If you're already going in first gear like 10 mph and then floor it, the tires will break loose! Mind you I'm running 225/40/16 yoko's!
My experience on backroads...here's one good example. Going fast but have to slow down for one of those super tight turns heading up a mountain. I'm going too fast for first gear, try flooring it around the turn up the hill in second at 3200 rpms...it pretty much bogs and accelerates o.k. That was before.... Now same turn, I go through the turn in second flooring it, then start to straighten the wheel coming out of the turn and flick the switch.....vroom! holeshot! The friggin' car scoots out of the turn up the hill like a v8! No boggin, just accelerates with authority from 3200 rpms+.
Well sorry for the long post, just passing along impressions
(too bad this didn't count for like 4 posts!)
