1991 red se-r ported,polished & extrude honed
heads,upper & lower intake manifold.the place CAI ,RC engineering MAF & throtle body, competition 4 angle valve job,turbo cams(car idles like a *%$#@ smallblock V8 at the track!),.020 overbore with 11:0:1 JE pistons ,crank bearing journal enlarged with bigger bearing, engine balanced and blue printed rebuild,JW ECU,stillen 4-1 header, fuel press. riser,MSD6al ignition,no egr or emissions crap, UR ss pulley set, pretty much every bolt on out in the market ,no cat,
[email protected] 17dg. plugs gapped at .035,short throw shifter, nismo sway bars, energy suspension complete master bushing set( the whole car), motor mount inserts all, centerforce dual friction clutch whith lightened stock fly wheel, custom mandrel bent 2&1/4 dyno max exhaust, yamamoto racing rims 15 x 7, nitto 205,50vr,15 tires.whole engine polished out for looks.
next is nismo brakes and SS brake lines. thank god for law suits! the race rebuild alone cost over $6000.all out motor was well worth it!over 200 hp 2100 rpm at 55mph on 5th!
[Edited by redman007 (09-24-2000 at 09:27 AM).]
