1 - 20 of 61 Posts
Which is better? Andreas says 20v has superior design, so it must flows like Hondas or better. But is it better then N1 head?
http://sr20forum.com/showpost.php?p=1924343&postcount=357
Andreas Miko said:
I sent a 20V head to SR20turbo freak and he was very much impressed with head.
The valve stem is 5.5mm but necks down to 4.5 mm in the port. The 20V head runs incanel valves which are super light.
From what Charles has seen he feel the 20V head is on par with flow as a K20 head.
K20 head 35mm valve with 6 mm valve stem
20V head 34.3mm valve with 5.5mm valve stem necked down to 4.5mm
This means the 20V head has the same or slightly larger flow threw the throat.
Andreas, Charles, what you think?
El Amansa Honda
the 20V head kills the sr20ve head. in a lot of ways. Personally, a sr20ve/ N1 type head can never be like a 20v head. the 20v head ports are atleast 1/8" taller and wider, not sure how much exactly but the port also has a smoother taper. the divider wall is longer too.
i would put the stock 20v head in between a stock B18C5 ITR head and a K20a head.
What does a stock 20v head flow and a stock b18c5 and the k20a head.
Hmm.. Can we use the 20v head with conventional VE bottom?
Discussion Starter · #10 ·
But why SR16VE N1 is a 197hp stock and the SR20VE 20V just 204hp stock???
It's 1.6 vs 2.0L, 400cm3 difference!
CAR SLÜT
N1 head has more aggresive cams and makes power at higher rpm, not to mention the N1 has a much more aggresive ECU tune. The 20V ECU programming is far from impressive, it was designed for a linear torque output as the P12 is not exactly a 'race car' like the N1.
Pat Pat Pat
If you found a p12 20v head, it would prob still be bolted to the block, why would you want to put it on a p11 sr20ve bottom end with a 4 counterbalance crank?
Im gona find a 20v engine and bolt it in EVLNXR one day, put the turbo engine in the corner and tune up the 20v to take on the Honduh boys at the drag strip running the k20 engine.
Evil plans ahead.
As soon as the wife will let me spend the money.....
I'm Coming For You
Read my first post. N1 - Aggressive cams(springs and retainers to handle revs), shaved head(Higher compression), and ported from factory. The motor also revs higher which creates greater peak horsepower. The N1 can be duplicated if your where to buy a regular VE head. The 20V as already stated cannot because it is competently different.
No longer a member
Although I may be too tired to realize whether or not someone already said this:
IIRC, all SR20VE and SR16VE heads are the same minus the 20V. The only difference are the cams and the N1 is shaved down a bit to increase C/R. Someone correct me if I'm wrong.
The 20V is a completely different head all around, better flow. Miko said it's on par with the K-series, maybe a little higher.
Discussion Starter · #19 · (Edited)
Discussion Starter · #20 ·
SR20Turbofreak, so the BEST head ever is 20V head, and I can bolt on it to my SR20DE/VE bottom, right?
1 - 20 of 61 Posts
