1 - 11 of 11 Posts
Well well well...here we go this time I ordered from Soko...and still got a demon engine....what is this
http://www.geocities.com/toddles8220/Engine1.JPG
Pictures are from 1-15
so chane the 1 to a 2 and so on.....I can't get my ftp transfer program to work with them...some one tell me this is a JDM engine and not lie to me....Head Code is 94 Y (my US was a 94Y), looks like a US header I don't have a clue what intake manifold that is......any ideas again????
EDIT: It says SR20 on it and sorry about the bad resolution, i can't take pictures (my cast) so my dad took them. This is engine number 4 by the way.
1995 200SX SE-R
Primera Swap I thought | Place CAI | Courtesy B-pipe & Thermal Muffler | ACT Disc | ES MM | Pro-Kits | AGX's | Courtesy Front STB
[This message has been edited by Toddles82 (edited 09-21-2001).]
pwnd
That appears to be a low port us motor. Just like what would come out of a 98+ looks like. All that tubeing is from a 98-99 motor I think. Appears to be juat a regular USDM 98-99 sr20de. Hope you werent expecting a premera motor....cause thats not one. I could be wrong but that appears to be it to me
From the VIN on the block, its at least a '97 SR20. The heat shield looks to be a '98+ car. Where are the other pics?
EDIT: It looks like you are the proud owner of a '98 or '99 SR20. You can do a cr fax search using the VIN on the block to make sure. That is a clean ass motor. You can use the intake manifold from your old motor on that one. If you have any cams, swap the intake cam.
Eric Waterman
1996 200SX SE-R
1997 200SX SE-R
1991 Sentra SE-R
[This message has been edited by eric96ser (edited 09-21-2001).]
www.motorists.org
Yup. Looks just like mine, only brand new!!! Damn is this a new motor? It's cherry. Only thing I don't have are those two gold brackets which I assume you put on there to lift the motor with? On the front-left and right side of the VC?
Ben98SentraSE
98 Sentra SE and crashed 93 NX2000
1 - 11 of 11 Posts
