ManiakCA
I want to run a sr20det (silvertop) without the turbo i know that the oil lines would need to plugged up but what else?
the motor is already in the car with the passenger motor mount is attached just need 2 more motor mounts to hold the motor in the car,
HOw much would a shop charge me to plug up the oil lines and put on the accesories ?
please help me out,
209-704-2626 text me with info please
Still not my president
you need to plug the oil lines the coolant lines also the injectors are going to be to big for a n/a motor so if you have the reg 259cc injectors i would suggest dropping those in along with running a n/a ecu and all other sensors. basically you want to take everything off of your n/a motor and put it on the new motor. then plug the random holes up.
You also have water lines to plug. Other than that, what injectors/maf/ecu are you running with this setup?
