ok my friend has a nissan ser he wants to put some new parts in his engine but not a turbo he wants to keep it all motor. my questions is what all should he put in his engine as far as cams (s3 or s4) would he also need to change his ecu or injectors if he was to change his cams or anything else? cool air intake,headers,exaust system 2.5 or 3.0 also would he need a bigger fuel pump any other suggestions would be great to here. hes looking to get close to 200hp. thanks guys
The Genesis
s4 cams are pretty aggressive....designed for turbo. he can change them without having to upgrade the ecu, but if he does upgrade to a JWT ecu, he will get more outta every mod. exhaust system should use 2.5, 3" is for turbo applications. at the moment, dont mess with the fuel system
GT2835R
I takes a lot to get to 200hp. Hs cai, gen6 header, c6 cams, springs and retainers, cam gears, and a lot of other stuff. If he wants a fast all motor car for cheaper then all the bolt ons is an sr20ve.
