It is a long story but in brief I purchased a U13 motor with precision SC61 turbo, protec manifold, aftermarket fuel rail w/ precision 720cc injectors, 3" downpipe and 3" intercooler piping.
The reason I purchased the motor was more or less for the built bottom end for reliability purposes. I really do not intend on laying down the horsepower this set up is capable of. Please keep in mind I have not install the new motor as of yet. So, if you have any suggestions that I should replace while the motor is out please let me know.
Anyway, I want to bring it back down to a semi-stock setup. So, I have already purchased a U13 Manifold. My questions are below:
- What are my choices of turbo's (T-25, T-28, etc.) I can mount to my U13 manifold?
- Should I stick with the 720 cc injectors or go with the 370cc injectors?
- Will the injectors from a Z32 work on the stock fuel rail from a SR20DE?
- The precision turbo mounts on top of the manifold, does that mean I need entirely different downpipe and J-tube?
- I assume I will need the stock water and oil lines, correct? Is there anywhere I can get new/aftermarket water and oil lines?
- I have 3" intercooler and piping will these work with my new turbo setup?
- Can I run the Nismo Adj fuel pressure regulator with the new setup or do I need to go with a SARD or Aeromotive?
- I plan on running a SAFC II, I assume I can stick with my stock ecu, correct?
- Would the recirc BOV that JGY sell work with my new turbo setup?
- Will my stock MAF work with my new setup?
Thanks in advance,
Brian
Thanks in advance,
Brian
