NEW T04B Turbocharger​
BRAND NEW FOR $400​
This is for a NEW (not rebuilt) Borg Warner T-4 oilcooled turbocharger. The turbocharger is in the factory packaging and has 0 MILES ON IT!! The A/R on the compressor side is .60 and on the turbine side is 1.00. The Compressor side has a 2.75 inch inlet and a 2 inch outlet. Also, the compressor wheel is an S-trim. The turbine side is tang divided 62 trim for super fast spooling. The turbine side also has the standard T3 flange for the inlet and a 2.75 inch V-band outlet. Gaskets are included.
PICTURES AVAILIBLE. PLEASE LEAVE YOUR EMAIL ADDY!
-Notice the flanges. The exhaust inlet (This is the black inlet that has the rectangular bolt pattern) is the Standard t-3 flange as found on most aftermarket exhaust manifolds. Anything different from this flange will most likely require custom modification to your aftermarket turbo manifold.
-The inlet and the outlet of the compressor housing (this is the silver side) has the standard round flanges. This means that all you need to do is use silicon hoses and hose clamps to connect your intercooler piping to the turbo. This is much easier and more effective than the other turbos that require you to bolt your piping to the turbo.
*ALL GASKETS ARE INCLUDED*​
Audio Nut
pic's please: [email protected]
This have an external WG or internal? (stupid q, probably ext., but I had to ask)
-Travis G.
