1 - 10 of 10 Posts
Time to put all the projects on hold for now. I have a new, Garrett GT2871R dual ball bearing turbo, rated at 475hp. This turbo is the bolt-on upgrade to the GT28RS (aka disco potato)
This is one of the best street turbos I know of for the sr20det or ca18det. Specifically designed for small displacement engines. Rapid spool. Requires a 0.035" restrictor for the oil feed line.
Applications
sr20det FWD, RWD
If you want to use this on a FWD sr20det, just let me know and I'll supply the bracket needed for the wastegate and the front engine mount.
Garrett Part number: 743347-2
Here are the specs:
http://www.turbobygarrett.com/turbobygarrett/catelog/Turbochargers/GT28/GT2871R_743347_2.htm
SOLD SOLD SOLD
Click on image for bigger view
Applications
sr20det FWD, RWD
Here are the specs:
$1100 OBO Shipped
check your pm,,,,
BTW that's rated in flywheel horsepower, but it is good to just over 400 whp either way.
Yessir. The highest I've seen one of these dyno so far on an sr20det was over 400+whp @ 18psi on pump gas. It's an awesome street turbo with quick spool up and off course ball bearing goodness :biggthump
1 - 10 of 10 Posts
