How difficult is it to install one of these? Any write-ups out there that can help guide me through this?
Discussion Starter · #2 ·
Well I just found the quaife install writeup from 98sr20ve. I guess that should apply to this as well. Is that really all I need to install the nismo unit though? Do I need to change any seals or bearings? I'm asking this because I noticed an LSD install kit on the sr20dev website: $255 Install Kit for LSD (Bearings, Speedo Gear, Etc...). I didn't see any of that on 98sr20ve's writeup.
jacen99SE,
I found your post and you wrote you needed these parts:
38440-D2100 (you need 2) bearing
38431-D2100 Speedo stopper
32701-D2100 SPeedo drive gear
Will I still need to buy these parts if I am just transfering the LSD from one broken tranny to another tranny?
Also 98sr20ve wrote this in his writeup:
4. Three bolts hold in the shifter mechanism and three more hold the gears in. Remove all 3 and remove the gears, paying special attention to how they all go in.
I'm having a little trouble here. Do I remove the 3 shifter bolts and the 3 gear bolts (6 bolts) or just the 3 gear bolts. I'm having a hard time getting to the third gear bolt because it's inbetween some gears.
SE-R-2-Go said:
jacen99SE,
If the used NISMO LSD already was installed and working, you do not need to replace those parts unless they seem bad.
You want to remove all 6 bolts. I had to go back and look at some of the pictures I took and some of the pictures steve provided to remember that. Also, play close attention to the way the small gear by itself is installed.
