thanx guys.That is basically a DET turbo journal bearing. It's original application is for the s13 det.
If you clock it it will work fine for fwd.
Mike
Welcome man! :biggthumpI'm oficially on the Nissan Turbo boat guys :biggthump
Damn, I am boost addict and I admit it.
I got, now confirmed, a W10 engine in pretty good shape (so far, so good). The turbo has p/n 14411-1E001
Let's get it on baby!!!
Pics coming soon....
Vadim (CovertedRussian), I told you I would not let you turbo alone bro![]()
Already have:
W10 Avenir engine
Nismo's 740cc injectors
JWT S4 cams
JWT ECU (at JWT at this moment being loaded)
JWT Pop Charger
Walbro 255lph
Nismo FPR
Z32 MAF
Stock turbo for now.... let's see what this baby can do![]()
Here I come!!!
Uhhh there are plenty of websites that sell them. It will be better for you to start a new thread in general discussion not to spam this thread.hello,
I have one question, can you tell me where can I buy Avenir engines in california?
Ah that makes sense now. The 6 wire tps form a low port, like Wolf_SER's, doesn't fit too easily. You have to modify some things like on this page, you'll have to scroll down a bit though.6 wire TPS is for the auto W10/W11/U13 motors
Just fit the SR20DE TPS or keep the 6 wire TPS and use the top plug
Did you check the part numbers to make sure?According to this i have a w10 but stock boost i have is 9lbs
Did you check the part numbers to make sure? Also said:Yeah part #'s match.. and the exhaust isnt even done yet.. its 2.5 DP to 2.25 stock catback (Till this weekend when it will be 2.5 all the way)
You mean that I should use the 3 wire tps with throttle body and use ONLY the top connector of the 2 I have (6 wire)? If this is the solution, this would be AWESOME!!!6 wire TPS is for the auto W10/W11/U13 motors
That's already bigger then the stock dp. I think the stocker was around 2.0-2.25".Yeah part #'s match.. and the exhaust isnt even done yet.. its 2.5 DP to 2.25 stock catback (Till this weekend when it will be 2.5 all the way)
Yep that's basically what I was saying yesterdayYou mean that I should use the 3 wire tps with throttle body and use ONLY the top connector of the 2 I have (6 wire)? If this is the solution, this would be AWESOME!!!
I already have a 96 JWT ECU which uses the 3 wire tps and I did not had any problem using the 6 wire tps so it makes sense to use it the other way.
I have to complete disassembled TB, the one from my lowport DE and the one that came with the highport W10 DET, I thing both are goners as we totally tear them apart, trying to interchange the shafts between them (damn it was way easier just to cut the excess of the longer shaft but we didn't thought of it)
Thanks man. I really apprecite it. Here's the info taken from the Nissan ManualThat's already bigger then the stock dp. I think the stocker was around 2.0-2.25".
Or maybe your W10 came from a powerthirsty Soccer Mom:biggthump
Yep that's basically what I was saying yesterday![]()
orly.According to this i have a w10 but stock boost i have is 9lbs
Thanks for the tip. I will double check this.You can even use a multimeter to check the resistance in the pins to confirm they are identical.
When you refit it, make sure the TPS tab is in the right spot inside the throttlebody or you will not be able to get full throttle TPS voltage![]()
