Guest
·Guest
I finally got the brakes to work. Now I have several new questions.
I ended up replacing the front pads. The replacement pads that matched the old ones were listed as the pads for an ABS equiped NX2000 (my car is non-ABS). I installed these pads and they fit into the caliper, but the inner pad extends about 1/16 of inch past the diameter of the rotor. I measured the rotor thickness and came up with 24 mm. So I assume these are the right rotors that have just worn somewhat.
Anybody know why the pad would extend past the rotor? This is incorrect isn't it?
Are the Front ABS and non-ABS calipers the same? How about the rotors?
