· SE trying to be R
ok so im going wensday to test drive a NX2000 im pretty much STEALING(verrrrrry low price)i know it has a few minor problems but is there anything in perticular i should look for while driving it? and is 5th gear pop out common on the nx's like on b13 se-rs? just tryin to get an idea of what i should look for and as soon as the cars in my name ill relese the price im payin(so no one trys to buy it before me:D) but yeap any advice or insight from current NX2000 owners would be very much apprecaited
· SR powered S13 coupe
Rust - check A pillars, fenders and rear strut towers (under the carpet), these are the most common area's for rust to start.
5th gear popout is easily enough to happen on a NX as it is on a sentra. load in 5th gear is a good test to see if it will pop out or not. Find a small hill that you can drive in 5th gear.
· SE trying to be R
top of the strut towers or bottem? and im pretty sure since it has a JDM motor and tranny in it with "lower miles" it shouldnt have 5th gear pop out now that i think about it but i know a great hill to test it on
· Master of Swordchuckery
pull the carpet to expose the whole tower
· Light weight thinker
Check the T-tops for leaks by spaying it a car wash lightly. If you really power it right on the top, it WILL leak. It only needs to hold out rain. Unless of course you're buying a rare hard top model.
Ask if the waterpump has ever been replaced. They are a real b**ch to get at.
· SE trying to be R
thank you guys ill keep all of this in mind when i go to test drive the car :D
· Shift_2.0
Take off the oil cap,and look in with a flashlight.You will be surprised how much you can see in there.
It isn't as good as taking off the valve cover,but if it is neglected,it will be obvious.
Other wise...popout and rust are the biggest concerns on an NX from my experience.
