Well one day I phoned up Andreas Miko on the phone and he came up with a great idea of running a Primera Roller engine except removing the head and using a high port head and using the 10:1 compression ratio he also said this engine contains no girdle and would produce more HP I'm very intrested in this setup and was wonder about this setup I'm intrested in putting C3 cams in them what are you predictions on this one Andreas?
92 SE-R lots of dents
S4 cams, Hotshot4gen header,2 set pulley,hayame exhaust,
[email protected] with melting cracked CAT
