Would buy a set of JWT VE Cams, springs with in the first year of production
1 - 20 of 146 Posts
Basically, the cams would cost a couple hundred more then the existing C cams and spring setup. They would have an upper grind similar to the new JWT C6m cams. All cam specs and profiles would be determined by JWT. Expected power increase would be from about 180whp to about 220whp. RPM limits would need to be determined but it would likely be well over 8ooorpm with the right engine setup.
WASHED UP
Yes but for some reason i can not vote.Ok i guess you fixed it :)
SE-R BUM
The ve is going to produce this much power, Im for sure going to buy these once they are out... lets get the show on the road! :D :D :D
Turbo Grocery Getter
Any word on a new VE program that will let you use that whole powerband? Maybe they can package all this together.
nathan
Discussion Starter · #13 · (Edited)
Mike stated earlier that the cams would likely have a JWT specific program and the higher redline as well. His ECU is set up for much higher then 8K.
Charlie Brown look alike
I am definately in.
seen the light
Course I'd buy them...it's what we're all waiting for...Good to see you here, Mark(foneguy)
Andy
1 - 20 of 146 Posts
