El Chingon
Sup everyone! Just a quick question for ya.. for anyone running a T3/T04E, what size of oil feed line did you use? I need to buy a braided line to feed the turbo, but don't know what size to get. Also, did you have to use any kind of restrictor in the line to limit the oil going into the turbo (to avoid excess pressure and blowing seals). Anyone? TIA!!!!
David
'98 Super Black SE w/stuff
I believe you want to run a -3 line, -4 is too large!
http://members8.clubphoto.com/louis419830/439477/guest.phtml
Louis Anaya 1992 Sentra SE-R
349.6 hp & 301.9 ft/lb @ 19 psi, 12.0 @ 118.77, Bluebird SR20DET, T3/T04E, Deltagate Wastegate, FMAX Manifold, RevHard FMIC, JWT S3 Cams, JWT Ported & Polished Head, 1996 200SX SE-R Welded & Cyro Treated Tranny, ACT Xtreme P/PL & 6 Puck Disc, Cobra MAF, JWT ECU w/ 4 Bar Fuel Program, MSD 50lb/hr Injectors, JWT Fuel Rail, 300ZXTT Fuel Pump, AeroMotive Adjustable Fuel Pressure Regulator, Greddy Type "R" BOV, Greddy Profec B, Greddy Boost & EGT Guages, UR 4 Pulley Kit, Powerslot Rotors, Axxis MM Brake Pads, ES Motor Mounts, Topspeed Short Shifter, Momo Cobra Shift Knob, KYB AGX Struts, GC Coilovers (350F/600R)& 17x7 White Tenzo Shu-4's w/ Yokohama 205/40/ZR17 Tires (Street), 13x7.5 White Lenso VPD's w/ Mickey Thompson 24.5x8x13 Slicks(Drag)
El Chingon
Is this what you're running Louis? Dude, the car's almost ready!! I'm bringing it back to this side of town tomorrow, so I'll give you a call so I can show you my new toys
David
