i just discovered an oil leak, pretty bad. its on the side of the transmission to upper oil pan. there are no bolts holding this there its just lined up. anyone else have this problem.
rollin 4 deep with JoeD
What do you mean "there are no bolts holding this there its just liend up." Can you explain in more detail?
IT sounds like your rear main seal is leaking, if its weeping out where your tranny mates up to your block.
Ill try to take a picture. Its where the trans meets the upper oil pan. I looks like to half circles meet.
