Hi guys
Sr20 newbie here, based in NZ. Recently had my starter motor go on me, so pulled it out and had it reconditioned, allgood now my oil pressure light on my dash has come on. I'm getting paranoid because I have a baffled sump, car was jacked up from the front and left on axle stands for a couple days, only front up, not whole car . Got starter motor back, installed, and started it up while still jacked up (remembering it had been up like that for 2 to 3 days) now just for my sanity Is there anyway that the oil pump could of run dry for the 5 seconds the car ran briefly while jacked up? Since light has been on, I've topped oil up, which was sititng about mid way level is perfect now, car will run and sounds smooth, have disconnected coil pack turned over for 20 seconds to prime oil. Have unplugged sensor switch and light isnt turned on, so plug is obviously working fine. Any help if any would be appreciated. Cheers
