SLOW SE-R
Can I get some tips on replacing my oil pump in my 97 SE-R? I want to replace it with the engine in the car. Oil pump is NOT WORKING AT ALL.
wants to go play
It's not fun. Make sure you have enough jacks and stands to support the car and the engine seperatly since you have to remove the front to rear subframe to get the upper oil pan off. When removing the timing cover be very careful to not tear the head gasket. If you have access to a lift, use it. I did mine on a lift and with 2 people it still took 7 hours.
SLOW SE-R
Finally some input. Thanks
