1 - 2 of 2 Posts
After having my valve cover coated I have notice a significant
increase in oil consumption. My understanding, from reading the SE-R
List archives, is that there is supposed to be a "brush" somewhere
between the valve cover and the oil separator that is really an oil
mist/air separator. Where does this go? Is it available as a
separate part? Can I install it without removing the valve cover?
Also while researching in the archives, I came across a reference to
a "breather filter":
"For those doing this, you can use Deutsche "breather filter" #BF404,
available at Autozone, on the hose that goes from the oil separator
to the stock airbox. This was Jim's advice, but I thought I'd share
the part number while I had the box sitting here. By the way, this
part is about $2.00.
Cason Grover"
What exactly does this piece do. Would it be used with a PR CAI? If
so, where?
Lastly, at the same time HPC was coating my valve cover I had them
coat my oil separator. Prior to painting it the "heat clean it".
Could this "heat cleaning" effect it's function? I was under the
impression it was all metal construction, including the interior
element.
93 SE-R JWT S3 Cams, JWT ECU, PR CAI, HS Header,RT Cat, HKS exhaust, Hypercoils, KYB-AGX, ST Sways, N-Tech Brace.
<font face="Verdana, Arial" size="2">Originally posted by Andrew:
so, where?
hey i have the K&N version of this on my car. if you look in between my wires and the CAI you can sorta make out a little filter: http://personal.lig.bellsouth.net/lig/r/a/rapntap/engine-bay.jpg
i'm not real sure of the *performance* value. but it does look better than a tube!
1 - 2 of 2 Posts
