After having my valve cover coated I have notice a significant
increase in oil consumption. My understanding, from reading the SE-R
List archives, is that there is supposed to be a "brush" somewhere
between the valve cover and the oil separator that is really an oil
mist/air separator. Where does this go? Is it available as a
separate part? Can I install it without removing the valve cover?
Also while researching in the archives, I came across a reference to
a "breather filter":
"For those doing this, you can use Deutsche "breather filter" #BF404,
available at Autozone, on the hose that goes from the oil separator
to the stock airbox. This was Jim's advice, but I thought I'd share
the part number while I had the box sitting here. By the way, this
part is about $2.00.
Cason Grover"
What exactly does this piece do. Would it be used with a PR CAI? If
so, where?
Lastly, at the same time HPC was coating my valve cover I had them
coat my oil separator. Prior to painting it the "heat clean it".
Could this "heat cleaning" effect it's function? I was under the
impression it was all metal construction, including the interior
element.
93 SE-R JWT S3 Cams, JWT ECU, PR CAI, HS Header,RT Cat, HKS exhaust, Hypercoils, KYB-AGX, ST Sways, N-Tech Brace.
Yes, it appears I do. I'm convinced it has something to do with my oil separator and or lines running from the valve cover to the intake and oil separator.
