1 - 14 of 14 Posts
El Chingon
Oh, you only got the ones on the crossmember, right? Naw, those are cake. They're all cake, the only hard thing is that when you get the other two (PN 7-1106) you need a press to press the big round one in. But, you just have PN 7-1105; those are easy.
David
'98 Super Black SE w/stuff
<font face="Verdana, Arial" size="2">Originally posted by nsracer:
The mounts are sweet I think. The wheel shakes at idle, less wheel hop. The only mount that's a major PITA is the passanger side mount. It has to be punched out....or done with a ghetto set up (pipe wrench and punch and about an hour if you do it at midnight). Get all 4!!
1995 200 SX SE-R hydrolocked SR20DE that had PR CAI | ACT Disc & PP | ES MM | Pro-Kits | 17* timing | Courtesy Front STB | Courtesy B-pipe in garage | AGX's in garage
i love the mounts! =) I havnt had wheel hop since. to me it makes acceleration feel more direct. When i used to roll in 1st, then punch it, my car would kind of wobble for a moment, now it just puts it to the street.
and yea they are just cool to have
markp
es mm equipped
via seattle se-r
JordanWhiteMusic.com
Peters car needs mounts BAD. He has the ECU and when shifting at 7800rpms his engine clunks around up there. Get those mounts peter
Stormy
Black 1998 Sentra SE w/ HS CAI, HS G3 Header, Custom 2.25" Exhaust, JWT S4 Cams, UR Pulleys, KYB AGX's, Eibach Sportlines, Courtesy STB's, ES Mounts, ES control arm bushings & shifter bushing (NI), PWST X-Drilled Rotors w/ Axxis MM Pads, 205/50 Pirelli's, Nis-Knacks goodies
www.WhiteLineRacing.com
Discussion Starter · #14 ·
If you like your car to stay quiet, I would recommend against getting all four. I did three and the resonance from 4-5.5k is enough to drive me crazy. I'm planning on removing the side one (which I heard makes the most noise) and will probably loosen up the back mount to reduce a little noise too.
1 - 14 of 14 Posts
