I'm going to be doing my tranny swap in the next few weeks and was wondering if someone could post what needed to be switched over to make the 95 tranny work w/ the 92. I know the speed sensor was one of them but what else? TIA guys.
Mel
· _______
Replace your axle seals. The speedo sensor is a simple bolt on/off thing you just swap the mechanical from the electronic.
Their is an extra sensor on the 95 trans tho. Its in the front near the radiator fans. If the trans you get has the sensor in it just leave it and snip the wires. If it dosent have it in find a bolt that will fit and cut a small plate of metal and bolt it over the hole. No bigge you just don't want an open hole where "things" can get sucked in or out...
Mike
