If the wiper arm isn't stripped off pull you cowl cover off.nx2000racer said:i bet its the nut that holds the wiper arm in place... i see it all the time
you probably dont have to remove anything, just maybe pull a cap off the top of it at most. then check the nut to see if its tight
otherwise i would assume the linkage broke going to the other wiper.
is the cowl cover along the underside of the windshield?Its311Pete said:If the wiper arm isn't stripped off pull you cowl cover off.
all that holds it in is 3 phillip head screws and a couple of clips and you can see the arms and linkage.
Yes it is between the bottom of the windshield and the rear of the hood.95se-R said:is the cowl cover along the underside of the windshield?
