"The world is yours"
i think i blew my ecu when i was messing around with it today.
the engine turns over but will not start. is this a blown ecu or what. dont want to buy a ecu when its something like a relay or fuse.
HELP!!!!
Enjoy the GTR Matt!
make sure those two wires that branch off the main harness next to the ECU are still connected to their clips. I had the same problem after doing the first swap, that one connector with the 4-6 wire connector is what you need to be clipped in.
Turn your key to "on", and see if you have a light on the ECU, and if it will report error codes. If it does, then nevermind my suggestion isn't it. If you don't get a light on the ECU or error codes, check out that wire harness clip.
