Before you flame me I tried everything and am still getting poor mileage--around 190 miles a tank at $3.15 a gallon PLEASE HELP!!!
Here is the rundown--I changed: cap,rotor,wires,plugs,PCV,O2,IAC,MAS,FPR& fuel filter.
I adjusted the TPS,fuel press. to specs. Replaced the injectors (2 were bad). Removed the EGR, BPT & CAT converter.
The mods on the car are S4 cams,HS header & intake,Larger TB,Stromung cat back,Test pipe,JWT ECU, clutch & PP, Walbro fuel pump.
As for the timing I cant be sure but the light shows 15 deg. and idle is at 900rpm to smooth out the roughness of the cams.
Can anyone help me? Does anyone live on Long Island that has a consult to check this thing out,someone was supposed to help me but I keep getting the run around from him and I can't deal with this anymore.
I need to fix this before I put the turbo kit on. If I cant fix this I am going to have to get rid of the car and I don't want to do that.
Thanks in advance for any help I get.
